Keeping DevTerm A06 up to date
Hi all. I’m still kind of a newbie when it comes to linux and I got the devterm to toy around with and become more experienced with it.
From what I understand, I’m currently on Ubuntu 21.04 hirsute, which seems to be out of date. I tried following this guide: Hirsute went offline late July 2022, how to manage?
to fix it, but I’m unable to get it to successfully update. Should I be switching to a different distribution since hirsute is no longer supported? How would I go about doing that?
26f52bfde573479960d8696f407d19b9 http://dl.clockworkpi.com/DevTerm_A06_v0.2h.img.bz2
could you re-flash a new sd card with new os image?
in this later os image. we switched to jammy, which is a LTS version up to 2037
I’m running the latest image from clock work… only issue is they have not solved the screen blank issue - once the onboard screen has timed out due to inactivity it blanks out - I operate with an external monitor so it is not an issue but when I do there is no current solution other than force a reboot that can corrupt the sd card. DevTerm struggles to come back from display sleep
I want to suggest that you keep build notes - I have a set of instructions to load all the programs from a new install - highly suggest that you do that - I’ve messed up the OS installing programs having the install instructions allows you to rebuild the applications you want to use…
To re-flash I unpack that file and put it on a new SD card and reboot my devterm right? It’ll basically be installing a new OS? Or is this a smaller operation. Sorry, I’m not super familiar with Linux as I mentioned.
if you are in Windows or Mac Osx
uncomress downloaded file DevTerm_A06_v0.2h.img.bz2 , you will get a DevTerm_A06_v0.2h.img ,about 7GB
then use https://etcher.balena.io/ to flash the DevTerm_A06_v0.2h.img to the SD card
Select DevTerm_A06_v0.2h.img as Image in etcher, then SD card driver ,then go
and if you are not familiar with Linux , use another blank SD card for this
after flashing, insert SD card into DevTerm again, then Power On
here is a new os image for devterm cm4
included a updated kernel as same as uconsole
Integrated screen rotation at the kernel level.
Should I use the A06 image or the CM4 image here?
Sorry if you have a A-06 processor use the A-06 image. ! ! A-06 is for the A-06 processor variant!
no ,CM4 os image is for raspberry pi cm4 only and just came out.
a06 os image is still on the way
