I assembled my DevTerm last night, and installed the CM4 incorrectly on the first attempt.
The CM4 core module carrier board has an silkscreened outline indicating the correct mounting position. Align the CM4 with the outline and the two connectors. Then snap the module in place. If you install the CM4 module incorrectly, the outline will be exposed on one side and covered on the other.
There are no screws required for the CM4. The connectors make a strong bond that shouldn’t pop off once the DevTerm has been fully assembled.
Can you take a photo of both carrier board and CM module connectors?
I’ve assembled mine, and both connectors clicked after applying some pressure and remained attached after that…
I would very carefully pop the CM4 off the carrier (small flat blade). Examine the connectors on both for damage. A fair amount of force is required to snap the CM4 in place.
Thanks for the suggestions. My assembly has been otherwise halted by a damaged keyboard so I need to wait for a replacement part before I can continue.
I did get the Pi attached in the end. I still think something is wrong with one of the connectors, one side “clicks” but the other side doesn’t. It still comes loose quite easily, but, it seems to be making a good connection anyway, and it stays connected inside the case.
I really feel like the assembly instructions should include a page for this step, however.
