How to edit menu order
To edit menu order, edit the items from “/apps/launcher/Menu/GameShell/” folder adding “index”+"_" to file / folder item, for example:
cpi@clockworkpi:~/apps/launcher/Menu/GameShell$ ls -1
10_Settings
20_Retro Games
30_CaveStory.sh
40_RetroArch.sh
50_freeDM.sh
60_Music Player
70_TinyCloud
99_PowerOFF
live example:
https://mastodon.social/@zital/100538104957417473
Nice hint, I cant stand seeing “Poweroff” item in the middle of the menu, it’s better in the end as yours.
ok
nice order
will include
You should know that if you update the launcher, you will have duplicated entries. You’ll have “99_Power Off” and the original “Power Off” will be downloaded again :frowning:
git reset wont able to fix this issue?
I guess so, but that’s not as straightforward as updating the launcher through the GS menu. That solution needs you to update the repo from ssh.
in fact
launcher’s update is just a git pull && git reset --hard hashnumber
so if git can handle rename issue of folders ,that will be no problem at all
:slight_smile:
Oh I don’t know that. I have had duplicated icons/folders when updating, so I went back to the default. Don’t know how if this behaviour has been changed.
created pull request:
merged!
