How to install DOSBox-X on uConsole?
How to install DOSBox-X on uConsole,on Raspberrypi
sudo apt install automake libncurses-dev nasm libsdl-net1.2-dev libpcap-dev libfluidsynth-dev ffmpeg libavdevice58 libavformat-* libswscale-* libavcodec-*
git clone https://github.com/joncampbell123/dosbox-x.git
cd dosbox-x
./build
sudo make install
dosbox-x
Thanks you very much.
So would it run DOS 3 or 6…
I think i have some stuff on floppy from 80’s hanging around somewhere in my office.
I haven’t used this, but I’ve had very good luck with the DOSBox-Pure core in Retroarch. It’s a fork of DOSBox designed to make DOS games play like console games: GitHub - schellingb/dosbox-pure: DOSBox Pure is a new fork of DOSBox built for RetroArch/Libretro aiming for simplicity and ease of use.
If you set up a Game Focus hotkey, you can switch to using the trackball and keyboard directly without using Retroarch’s other keybinds.
Thanks for Info! Will snag it Monday and try on a Linux build at the shop.
db
