How to show Gameshell display in Windows?
How do you show your display in windows , to take screen shots of the UI?
I already found this topic https://forum.clockworkpi.com/t/x11-forwarding-or-else-how-to-display-gameshells-screen-on-your-pcs-desktop/2380
and I installed MObaXterm , i logged in , all it does is give me a terminal,
Sounds like a duplicate topic to this:
Yes an no, he could have used the other topic but, he reference it and ask a clear question about it.
I personally don’t have a problem with using another topic to ask such a question. The category may not be the best but it is not worth asking to delete the whole topic.
Moved to Q&A
?Ive figured it out now, using this command
xwd -out screenshot.xwd -root -display :0.0
in SSH
sorry for the double post in another topic .
Don’t forget to include the rest of the instructions re: how to make the format readable.
Also, check your formatting. Usually I type DISPLAY=:0 in capitals. It could just be habit, but a lot of commands are case sensitive. It’s a different command, but just double check.
I’m guessing you found it in this post. I’ve linked it here, just to avoid repeat discussions going on.
