This review is going to be short for now because I just got time to tinker it for less than a day. But I’ll be updating should there be anything new.
1. The wait:
I ordered my unit(Silver, wifi only, CM4 Lite, without core ) on May 19th 2024, and received it on July 12th, so all together less than 2 months of waiting.
I wouldn’t say it is ideal but I have waited longer for orders from AliExpress so nothing to complain about.
If you want to receive your unit faster, go for the non-core version!
2. The Assembling
Not challenging for me. Everything was clearly stated. Excepted that I riped off the glued seal on the speaker. But other than that, nothing else worth mentioning. I am confident that anyone would be able to assemble it.
But I did notice that the back doesn’t fit perfectly. You can see a gap between. Maybe it is the thermal pad, maybe it is just the case itself. But it shouldn’t be a problem, I guess…
You can actually fit some A4 paper into the gap
3. The Actual Use
3.1 the Processing Power Test
I flashed the Stock Raspberry pi OS and also the Bookworm OS (which is a new experience for me) and I have to say I like the RBP OS better. It is actually easier to use than I expected. This would be a good start for Linux, but I am a rookie to Linux, so what do I know.
I don’t know anything that can run a bench mark so I managed to do it in a different way:
I’ll let it calculate all prime numbers between 1 and 100,000 in the most stupid way ever and see how long it takes
My laptop runs windows 11 on an Intel i7 10750H processor and it takes around 30 seconds.
And for the uconsole, which has a CM4 lite 108000 core and a 64gb A1 V10 SD card(I don’t know if V30 card would make a difference), it takes around 2 minutes. Meanwhile, the CPU use is around 90%. Overall, it is quite impressive.
3.2 the Display
The display is really good, and bright enough to use under the sun. I am really satisfied with it, except that it is quite small
I will be updating should there be anything new.
Peace ![]()
Update:
4. Benchmarks
I used Geekbench 6 to run the benchmark on CPU and compared that with my 4-year old budget gaming laptop and the result is as follow:
Pi CM4:
Laptop: MSI GF63 thin with i7 10750H and gtx1650 max-q on Extreme Performance Mode
It takes significantly longer to process and the terminal recognize the chipset as BCM2835, which I Googled and it says this is a KERNEL issue, but is normal.
Battery Life
For my use case, which is watching YouTube, learning Python on VS Code, and check Reddit and etc, for maximum brightness(I do this under the sun), the battery lasts about 4 hours.
Batteries are 2 protrcted cells with capacity of 3500mh each, made by Ansmann(My friend gave this for me as a gift).
Anyway, this is for now and I’ll keep updating.
