Kali for A06 uConsole
Hi
I’m working on getting a working copy of Kali for A06.
I’m suing as reference: GitHub - LofiFren/ImageEditor
@Rex, I saw you work. It’s amazing. If you have some time, could you please give me some advice? I was stucked on the boot loader side/partition. Generally, the Kali image is modified, and I have added the A06 kernel and bootloader, but I am missing something.
As soon as I have a working image, I will share all the process and the image itself.
Thanks :slight_smile:
Did you pack in the drivers as well? Can you share error messages you’re encountering?
Yes, everything is there. Unfortunately, I now have problems booting. There is no screen; the device is stuck somewhere, and I can’t see it. It also has no error messages.
Are you using an existing a06 kernel? And do you have an older uconsole or did you recently buy one?
Because at some point clockwork had to change the screen and this required driver changes. So you might need to compile a new kernel.
Thank you
I received my uConsole recently, and yes, I have added the kernel and the LCD extension.
I’m struggling with the boot partition of Armbian, and Kali solves the boot sequence significantly differently.
