Kali Linux 2024.3
Kali Linux 2024.3 kernel: 6.6.47
I saw a new version of Kali was just released, so I thought I’d get it running on the DevTerm/uConsole for everyone.
Username / Password: kali / kali
Raspberry Pi Imager will cause image not to boot if you apply custom settings.
Links to my working/testing images and kernels with the *.deb files to install in the mega folder if you want for different OSs.
Google Drive link for the image if Mega link doesn’t work for you.
https://drive.google.com/drive/folders/1tw2uPVPsFDhQ5Onx4mlllYexUDmDp0eK?usp=sharing
Hi, thanks for this link, it’s really great. Do you know if there is a version of DragonOS for the uconsole?
A big thank you again ^^
I haven’t seen anyone post that they made one. I’ll take a look at it.
Hey, since Kali is a rolling release, does your image survive apt full-upgrades?
It should, I replaced the stock kernel completely. Only after they have another release will we know for sure. you can run updates right now and it will all work.
Thanks man! Especially for the link!
Ah I just replied on the other thread about the XY compression and here you are doing it yourself and on GoogleDrive too haha. Thank you for your efforts!
This one is 2 Kali releases newer and a newer kernel then the one on the other thread.
Rex, how do you start the cellular modem in your compile of kali? I can’t find the command.
In the terminal
uconsole-4g enable
Then follow the same steps as you would with the other builds.
Thank you Rex! This works awesome! You are a genius. :slight_smile:
Thank you for sharing this with the community!
