Has anyone else had issues with their uConsole after doing a package update?
After running apt update and apt upgrade on my uConsole, the WiFi dissappears after it reboots. Although it appears under ip addr as wlan0 it just doesn’t startup.
So I wrote a fresh copy of uConsole_CM4_v1.3g_64bit.img onto another SD card and when it came up I did the update again on that fresh image and the same happened again.
After doing some searching I found this issue mentioning this problem from last year https://github.com/raspberrypi/Raspberry-Pi-OS-64bit/issues/217
So checking dmesg and there it is, regulatory.db becomes invalid so the WiFi cannot startup:
peter@raspberrypi:~ $ dmesg | grep regulatory
[ 5.170103] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.316711] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
I’m going to reimage that SD card again, but has anyone else had issues of just running an update and loosing WiFi completely?
