You should try some different settings in the mupen config file to determine the settings to run the rom flawless.
Edit: Btw welcome!
Edit: Btw welcome!
Thank you, Iāll start messing with it now!
can you please share me the compilation parameters of the *.so ?
thanks~
All steps done / executed scripts are written down in this thread already.
I got itļ¼thanksļ½
I donāt know why your *.so work perfectly, and my complied *.so very laggy.
You can have a look at these .deb files I created from my installation:
I am trying to run Mupen64 since it came installed on 0.4 but for some reason the roms are not loading i just get the loading screen then a black one and it goes back to the menu.
Thanks for the thread OPā¦
I got this working using the instructions you had in the OP⦠(using Clockwork image 0.3)
for people that only had audio like @doodom and @lasvegas ā I think that if the screen is black (in sleep mode) when you run the command via ssh, then it wonāt āwake upā. Maybe thatās the cause?
Banjo doesnāt seem to run very well though, even with the cfg you provided⦠Is it possible thereās some other configuration that we should be looking at?
Hello there,
I agree with the Sleep-Theory.
Everything I tried to get it running is written down right here.
That makes sense. Iām just thinking that there could be something different about your configuration prior to running those things.
Like have you maybe stopped any background processes or removed/replaced any system resources with some alternative?
EDIT: I also wanted to remind people to try using the āPerformanceā power setting for the best results.
Nope, nothing i can think of.
My OS (0.3) is just right out of the box without mayor customization besides the steps I described.
Would it be possible to create the core of mupen64Plus to use it with retroarch?
figured I would share this here.
if you have 0.4 and mupen is NOT working (which it doesnt out of the box)
what you have to do is use putty and edit /home/cpi/apps/Menu/20_Retro Games/80_mupen64+/action.config
and add āplugindir /usr/local/lib/mupen64plus/
see below for āinstructionā
cd /home/cpi/apps/Menu/20_Retro Games/80_mupen64+/
nano action.config
**ALTER** the line ROM_SO=/home/cpi/apps/emulators/mupen64plus --gfx mupen64plus-video-rice --fullscreen
**TO READ** ROM_SO=/home/cpi/apps/emulators/mupen64plus --plugindir /usr/local/lib/mupen64plus/ --gfx mupen64plus-video-rice --fullscreen
I personally also modified the EXT= line to read EXT=n64,zip,z64 from EXT=z64 because I have some non compressed roms.
Thanks for that! I can confirm that this does indeed work; albeit running extremely slowly using the either the FBTurbo or Lima driver.
I would suggest changing power profile to performance it does improve it with the hardware driver
Thank you for the steps, how would I do this on Filezilla? Or itās not possible?
EDIT: alright tried the steps but all I get is a black screen with just the sound of the game
Which version of clockwork OS are you using? I am on 0.4.
Did you do the Debian 10 buster update? I personally did.
Are you using FBTurbo or Lima? I tried both, and they work.
Are you using performance mode? I personally always do when running intensive processes.
Besides the last answer, I canāt speak for @duckyvirus, as I donāt know their setup, but for me, this is all I have done, besides follow the steps in this thread.
I could be wrong here, but the dependencies mentioned by @duckyvirus are quite possibly the same ones installed in the steps outlined above. From memory, the stock N64 mupen emulator includes is the standard link to a *.so file that downloads upon initial execution.
With that said, there would be little to no difference between the included emulator and the one mentioned in this thread.
If youāve followed the instructions in this thread, can you confirm if thereās both audio and video for the installed emulator?
Just for comparison sake, this is my action.config file:
ROM=/home/cpi/games/mupen64
EXT=z64,v64,n64
LAUNCHER=
TITLE=mupen64 Roms
SO_URL=https://raw.githubusercontent.com/cuu/emulators/master/mupen64plus.zip
Iām running os v4 with Lima driver
Honestly I donāt what the Debian 10 buster is lol
I can confirm that the audio for the game plays, but the screen stays dark, but Iām able to control the game
my change to the action.config (which would require downloading, editing and reuploading if using filezilla) is merely to let the downloaded version see where the .SO has been put.
I am waiting for dist-upgrade to complete and will re-confim that it indeed works once on buster.
Sounds good, I just donāt know why my screen is blank while the sound of the game plays
