Trying to use HDMI on my new A04 and I get nothing. xrandr doesn’t see HDMI-1 as a possible output. The cable I’m using is known good from use on my rPi4B and everything else on that board works fine. I do want to try another cable if I can find an adapter.
Hm, wait, you said you have HDMI-1 as output?
I don’t have HDMI in xrandr’s output:
> xrandr
Screen 0: minimum 320 x 200, current 1280 x 479, maximum 8192 x 8192
None-1 connected primary 1280x480+0+0 right (normal left inverted right x axis y axis) 0mm x 0mm
480x1280 59.30*+
Discourse does not allow to merge topic. Though as this topic is shorter, I will close that one. please go ont he other one to continue that discussion:
