New here, I am definitely getting power to console. All connections are flush and still no screen. The screen doesn’t even flicker when console is powered on. I receive the green light. The Pi is a CM4 and no eMMC.
I’ve attempted to flash the following to SD Card (128gb U1):
uConsole_CM4_v3.1_64bit.img
uConsole_CM4_v0.1b_xfce_64bit.img
Neither seemed to cut the screen on, please advise!
does the sodimm slot look the same? in your picture it’s kinda angled and not fully seated. how are you flashing the images? if using rpi-imager don’t use any custom settings like wifi/pass, username, hostname. it will cause the device to not boot. also do you have an hdmi for it? if so whats the output?
I was plugged in to power and believe the batteries are charged. do you suggest i let it sit on power and charge it over night and try the image you have in the morning?
did you attach the cm4 to the carrier board first? it’s quite easy to not fully connect the cm4 if you try to push down on it when it’s already installed in the mainboard?
also the wifi antenna on the mainboard can’t be used by the cm4, you don’t have to connect anything to that
thanks and understood, i tried it the way you suggested and I am currently atleast getting picture on a monitor. so atleast we know the board works at this point.
it seems like the CM4 is having trouble with the OS flash now, probably try to get this together before i try reassembly.
