None of my headphones fit in the headphone jack šŸ˜ž
The lip of the case stops my headphones from being able to plug in all the way since they have a slightly bigger plug than most. Does anyone else have this problem, and if so is anyone aware of a relatively unobtrusive way to fix it? I’m thinking either an extender or a modification to the case of the GS, but I’m not sure which way I want to go with it.
I would recommend something like this:
Though, you should be able to find a less expensive version.
I ended up going with
and it works quite well so far!
