NVMe on uConsole Manual(lulu)
First ,update your eeprom!See rex`s Guide
EEPROM config and the CM5 lite - uConsole - clockworkpi
After you combine Adopter and NVMe expension card(JUST CM5***CM4 cannot shutdown(AXP228 still works!!,if its hardware problem we wont fix this problem,we will take our attention to service CM5 better,just wait!!)***)
About the config.txt:you need change the line “dtparam=pciex1=on“
You have at least three easy way to boot your system on NVMe system!
FIRST WAY
boot on SD card (most people can do this ,someone cant boot on NVMe`s adopter,see SECOND way&THIRD way),use SD card copier just wait!,then take off the sd card ,boot on nvme!
SECOND WAY
If you cannt boot on SD card !just get a nvme card reader,all the thing likes TF card but faster.
THIRD WAY
SD card copy to USB3.0 **USB flash drive,**then plug Flash ,use SD card copier copy to NVMe!
ABOUT battery-AIO &new battery system!,just wait!!
Bump because currently relevant :slight_smile:
Sorry to bump, but only just got to installing the NVME. Im pretty sure there was more information here before?
any problem?l think this enough,this is not AIO nvme,is LULU nvme
