Hello fellows!
GameShell is a fantastic piece of hardware and I would like to contribute my 2-cents on this community by posting a tutorial on how to make GameShell run javascript games (using a game engine like Phaser.io with the help of NWJS.
I have uploaded this tutorial and related code to GitHub but I will also post README.md here for convenience. However for the latest updates please always check my github. Hope you find it interesting and useful!
GameShell + NWjs + Phaser =
Intro
The scope of this tutorial is to demonstrate how to setup an HTML5/JavaScript environment (NWjs) on Clockworkpi’s GameShell along with a JS game engine (Phaser) and deploy a simple Phaser example that is playable and controlled by GameShell.
Requirements
Clockworkpi’s GameShell portable console (https://www.clockworkpi.com/)
NWjs ARM binaries (https://github.com/LeonardLaszlo/nw.js-armv7-binaries)
Instructions
Installing NWjs on GameShell
First of all connect via ssh to GameShell.
Then download NWjs ARMv7 binaries (many thanks LeonardLaszlo) by executing the following command:
cpi@clockworkpi:~$ wget https://github.com/LeonardLaszlo/nw.js-armv7-binaries/releases/download/v0.27.6/nwjs-v0.27.6-linux-arm.tar.gz
Untar the archive with:
cpi@clockworkpi:~$ tar -xvf nwjs-v0.27.6-linux-arm.tar.gz
This will create a directory with all NWjs binaries. Inside this directory there is a lib/ directory. All the shared object files located in lib/ directory need to be copied to /usr/lib directory.
cpi@clockworkpi:~$ cd nwjs-v0.27.6-linux-arm
cpi@clockworkpi:~/nwjs-v0.27.6-linux-arm$ sudo cp lib/* /usr/lib
One last thing, NWjs requires another shared object library, libnss3 which is not installed by default on GameShell. Install it by running:
cpi@clockworkpi:~/nwjs-v0.27.6-linux-arm$ sudo apt-get update
and then
cpi@clockworkpi:~/nwjs-v0.27.6-linux-arm$ sudo apt-get install libnss3-dev
To execute the NWjs create a shortcut in the menu:
cpi@clockworkpi:~/nwjs-v0.27.6-linux-arm$ touch /home/cpi/apps/launcher/Menu/GameShell/NWJS.sh
give it permission to execute:
cpi@clockworkpi:~/nwjs-v0.27.6-linux-arm$ chmod +x /home/cpi/apps/launcher/Menu/GameShell/NWJS.sh
then open the NWJS.sh file (with vim or any other editor) and insert the following line:
/home/cpi/nwjs-v0.27.6-linux-arm/nw --use-gl=egl --ignore-gpu-blacklist --disable-accelerated-2d-canvas --num-raster-threads=2
Reboot GameShell and an NWJS icon should appear on the menu. Selecting it should run the nw app.
To exit the application it is needed either to switch off GameShell or kill the nw process id, sudo kill -9 PID. In the rest of the tutorial, a key shortcut will be added to close the application and return to the launcher by pressing the menu key on GameShell.
That’s all configuring NWjs on GameShell. The rest of this tutorial is the fun part of integrating Phaser game engine into NWjs
Deploying a Phaser.io Game
Like before, connect via ssh to GameShell.
Enter the directory where the nwjs binaries are, most probably in nwjs-v0.27.6-linux-arm/.
Clone this repository inside nwjs-v0.27.6-linux-arm/ directory
cpi@clockworkpi:~/nwjs-v0.27.6-linux-arm$ git clone https://github.com/pleft/nwphaserjs_tutorial.git
This will create a directoy nwphaserjs_tutorial/ inside nwjs-v0.27.6-linux-arm/. Rename this directory to package.nw. Doing this will allow the nwjs binary to pickup this repository’s phaser.io code and execute it.
cpi@clockworkpi:~/nwjs-v0.27.6-linux-arm$ mv nwphaserjs_tutorial/ package.nw/
That’s all, now selecting the NWJS icon on the GameShell menu will launch our little phaser.io game. To exit the game and return to GameShell launcer press the MENU key.
Significant code parts
Screen size
GameShell’s screen is 320x240 pixels, however setting in phaser.io the playfield’s size to exact match the screen’s size will result to the appearance of scrollbars. So it is set 2-pixels lower, 318x238.
var game = new Phaser.Game(318, 238, Phaser.CANVAS, '', { preload: preload, create: create, update: update });
Key mapping
GameShell maps its buttons to keyboard keys. This makes our lives easier and it is pretty straightforward to map GameShell’s buttons to phaser.io keys
UP = Phaser.Keyboard.UP -
DOWN = Phaser.Keyboard.DOWN -
LEFT = Phaser.Keyboard.LEFT -
RIGHT = Phaser.Keyboard.RIGHT -
A = Phaser.Keyboard.J -
B = Phaser.Keyboard.K -
X = Phaser.Keyboard.U -
Y = Phaser.Keyboard.I -
MENU = Phaser.Keyboard.ESC -
START = Phaser.Keyboard.ENTER -
SELECT = Phaser.Keyboard.SPACEBAR
Exiting the application
To exit the application and return to the GameShell’s launcher, nwjs command: closeAllWindows() should be called. Mapping this command to the MENU key is done as:
if (this.escKey.isDown)
// nwjs related code to close the application
nw.App.closeAllWindows();
