In case someone else runs into this:
- printer wasn’t printing but no errors visible
- lot’s of “Error:NO PAPER” in
/tmp/devterm_printer.log
I had forgotten to connect the printer cable to the board.
this could also caused by you forgot to install the devterm-thermal-printer-cm4 package if you’re using CM4. I ran into this NO PAPER issue and get it solved by sudo apt install devterm-thermal-printer-cm4
