Experimental all battery parameters in config.txt added
My uconsole build works down to 2.85V with battery min voltage 2.6V in config.txt. From full battery to shutdown is about 14 hours. I use 21700 vapcell f60 li-ion.
I think it’s possible to make the charging LED working when compute module is off. When I use battery holder and 18650 li-po, I used a small side punch to reset my uconsole. The batteries would disconnected for a moment and system would shut down, but charging led stays active.
I need help with github actions and releases version control. When I launch github action it must increase last number (7.0.9-1, 7.0.9-2, etc). If you want to fix this make a pull request.
