Question about uconsole screen whitening and edge backlight glow after long use
Hello everyone,
I have noticed that the uconsole screen tends to turn whitish after being powered on for a long time. When using a solid color wallpaper, it is especially noticeable that there is a glowing bright strip around the edges on the back of the screen.
Is this a common issue with uconsole screens or a normal characteristic of the display?
If it’s a hardware problem, does anyone have experience replacing the screen? How and where can I purchase a replacement, and what model or specifications should I look for?
Thanks in advance for your help and advice!
I think this is an issue with the drivers in the stock image, and it is solved by using one of the newer more up to date community images
The screen appears to be a custom screen so the only source for replacement screens we’ve found so far is clockworkpi themselves
@snipeytje
I’ll try it later. The system version I’m currently using is indeed quite old.
my current OS version:
the new OS version
the github images are not new(that link was last updated in august 2023), the up to date ones are posted here on the forum by rex
