I’ve got a display plugged in to the microHDMI port on the DevTerm, but I don’t seem to be able to get any output.
On reboot, I see this in the output from dmesg
[ 0.199831] [DISP]disp_module_init
[ 0.200403] disp 5000000.disp: Adding to iommu group 0
[ 0.239946] [DISP] disp_init_hdmi,line:1047:
[ 0.239950] dont support hdmi
[ 0.240357] raoyiming +++LCD_cfg_panel_info
[ 0.240435] display_fb_request,fb_id:0
[ 0.256841] [DISP] Fb_copy_boot_fb,line:1444:
[ 0.256845] no boot_fb0
[ 0.257361] disp_al_manager_apply ouput_type:0
[ 0.257763] [DISP] lcd_clk_config,line:731:
[ 0.257776] disp 0, clk: pll(330000000),clk(330000000),dclk(55000000) dsi_rate(55000000)
clk real:pll(324000000),clk(324000000),dclk(81000000) dsi_rate(150000000)
[ 0.258107] raoyiming +++ LCD_open_flow
[ 0.272681] <0>raoyiming +++ sunxi_lcd_gpio_set_value
[ 0.382658] <0>raoyiming +++ LCD_panel_init
[ 1.252847] [DISP] disp_lcd_gpio_set_value,line:2565:
[ 1.252853] of_get_named_gpio_flags for lcd_gpio_1 failed
I’m guessing this means that HDMI is explicitly disabled, but of course the main board contains the output connector for it anyway. It is not clear to me whether the R01 core / D1 chip could drive a display via HDMI? The wiki doesn’t contain a lot of detail on the hardware.
Is there something we could tweak in the kernel boot parameters to enable this? /boot/extlinux/extlinux.conf contains…
append earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 console=tty0 root=/dev/mmcblk0p4 cma=8M mac_addr=84:10:12:12:01:0
4 LANG=en_US.UTF-8 fbcon=rotate:1
I guess I need to dig in to the kernel sources and D1 spec to learn more!
FWIW, I’ve started to document various things I’m discovering on a GitHub repo. Feel free to have a poke around, raise issues, ask questions, tell me what I’m doing wrong, contribute etc! This is mostly a scratchpad / reference for myself, I am happy to migrate things into the ClockworkPi wiki if that makes sense ![]()
