Hi,
I cant get the r01 running with the waveshare compute module Poe board.
I recently received my r01 that I ordered together wit a uconsole. Since the uconsoles are not shipped yet I got the waveshare board to thinker with the r01.
According to the sunxi wiki the waveshare board should be compatible.
It is however not working for me and I am looking for way to figure out if the r01 is broken or the IO-board.
Here is what I tried
- I flashed DevTerm_R01_v0.2a.img.bz2 using balenaetcher to a 64GB sd-card
- plugged the r01 and the sd-card in there corresponding slots
- checked for the jumper to disable POE
- connected power via USB to the power USB port
The red and green led turn on and stay on. No flickering.
I can see on my USB power supply that everything pulls around 0.3 amps. Nothing else is happening. No video out, no network traffic, nothing on the UART.
I also tried a 32GB sd-card, two other usb cables, 2 other usb charger. I tried POE as well.
Am I doing something wrong?
Is the IO Board not compatible?
Is there anyway to tell if the r01 is ok? Is there anything I could measure to verify that the r01 is not broken?
Thank you for your help.
