Has anyone found a good way to mod the clockworkpi with a easy accessible reset button? It gets kind of old having to tear it apart to hit that button.
What do you mean? I probably don’t know of that reset button, never heard of it, but the power button which should be on the top, accessible from outside, serves a similar function (you can turn off and on, which would be the same as a reset?).
And if the GameShell hangs and doesn’t shut down “normally”, you can press the power button for 5 seconds (maybe 10, not sure) which will force a shutdown.
See I have had times, I could be not holding the button long enough, where it hard locks on incompatible roms. Where i have had to open the case and hit the reset button on the back side of the main board.
I’m sorry to hear that. Never happened to me and I didn’t even know there was a reset button.
I know nothing about “hardware” mod, I hope someone can help you out!
Just digging this post up as I’ve done a relevant mod to my Gameshell…
Adding an external reset switch is quite straight-forward, and can be done with very minimal alterations to the back of the Gameshell. In this case, I’ve modified the non-LEGO back, but it would work just as effectively on that back too.
Tools needed:
- Drill + 6mm drill but
- Soldering iron (and solder)
- two 3" lengths of wire
- one momentary switch with a 6x6x8mm cap
- flush snips
Process:
- Drill a hole in the top/right corner of the back case – you want to position it so that it’s roughly vertically centered, and has enough space for the switch to fit squarely against the inside edge of the case
- With the flush snips, trim away some of the top edge of the top/right inner retaining plastic (the top right corner that holds the mainboard module in place) – you just need to remove enough to fit the switch in place, so don’t cut it all the way out
- Dismantle the mainboard module, solder 2 wires to the exposed solder pads of the SW2 switch on the back side of the mainboard. You should solder the other end of the wires to the 2 legs on one side of the switch, and fold or remove the remaining two legs.
- Assemble the case, fit the new switch in to the space you drilled/cut earlier
Result:
Hopefully somebody else finds this useful!
