So I’ve been trying to figure out how to install retroachievements on gameshell, is this possible? I found one other thread on here, it tells me to find a config/retroarch file but I cannot find anything having to do with retroarch in the files.
Just curious if this is possible and if someone could point me in the right direction?
Cheers!
you’ll need an account at retroachievements.org
then the config options are these:
cheevos_username = "yourusername"
cheevos_password = "yourpassword"
cheevos_enable = true
for more infos you can check the documentation here: https://github.com/RetroPie/RetroPie-Setup/wiki/RetroAchievements
Yeah I’ve set this up on a retropie before, but i cannot find the config file inside of the clockwork pi. Otherwise I’ve set this up plenty of times, I just cannot find it inside the clockwork pi
Oh, ok - the config file usually is at ~/.config/retroarch/retroarch.cfg - hope this helps!
Whatever file browser you’re using will need to have it set to show hidden files. That’s what that period before config does; hides it.
The popup notifications actually work really nicely on the gameshell, if you have then enabled. Makes it feel like a real console; and possibly one of the main reason I will still use Retroarch over a standalone emulator.
