where i can find XMB set?
.config???
No, you enter those commands in the linux shell.
Thanks for that quality post
Awesome! Great job! Thanks a lot for comprehensive guide
I must learn about Linux first.
There are too many things I do not know too much since I got GameShell.
Hi mate. Thanks for the message. But I have serveral issues here:
When running “apt-get install git build-essential
apt-get build-dep retroarch” the terminal said: “E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?”
The github one runs ok. However, “cpi@clockworkpi:~/retroarch$ make -j4
Makefile:10: config.mk: No such file or directory
config.mk is outdated or non-existing. Run ./configure again.
Makefile:182: recipe for target ‘config.mk’ failed
make: *** [config.mk] Error 1
cpi@clockworkpi:~/retroarch$ sudo make install
make: *** [config.mk] Error 1”
Is there anything I am missing? Cheers
I think I ran it. “cpi@clockworkpi:~/retroarch$ apt-get install git build-essential
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?” got something like this.
The ./configure actually runs ok
You’re not running it as root like you’re supposed to.
Add sudo to the start of each apt-get command before running them.
That works! Thanks! Finger crossed for the later on things.
BTW, when I am setting the button configuration in retroarch. I accidentally assigned the confirm button (b) to something else. So I can click yes any more (so cant get it back). What shoud I do?
That’s the fun part
How can I set the directory ? I mean how can i even change the line from defualt to something else?
You press the OK button and it asks you to navigate to the dir
Thank you. Now I only have to figure out how to set up new directories. Great work anyways
You rock. Tnx!
Could I get a quick rundown on how to SSH with the GS? I downloaded Filezilla, but i’m drawing a blank here.
