When I run an ‘apt-get update’ on my system, it says ‘conflicting distribution’ in release expected devel but got kinetic.
I don’t know if this is because I am running ipv6, but the system won’t updaate.
sadness.
sadness.
chose Y did not work?
I edited my sources.list from dev to jammy to make sure I am up to date before any OS release upgrade
I had a similar error just recently, running apt upgrade -y fixed it.
Notice for apt upgrade:
apt upgrade on R01 os will mess up the content of extlinux.conf
lead the boot failed
so when this happens
mount the sd card(with R01 os) on a PC (like Linux )
then go into the boot partition of the sd card
you will see
extlinux.conf
extlinux.conf.cpi.bak
replace extlinux.conf with extlinux.conf.cpi.bak
the extlinux.conf.cpi.bak is for this kind of situation
I am following this advice to edit the boot partition of the sd
I have the sd card in my Linux laptop
I have found the _/boot
In it,
I see extlinux.conf which appears to be a text file which I can read, with Mac addresses and suchlike
I can see extlinux.conf.cpi.bak which I can open with vim
So I am going to cp the back up to the file name of the .conf file then sticking the sd in my dev term
