Risk v to CM4 main board help!
I have the uconsole r-01 that came with the risk v board- I wanted to put a rpi-cm4 instead. I ordered the cm4 of course it was the one with emmc, so then I had to order a waveshare io base board to flash, did that. Then i see that I have a cm4 to cm3 adapter and that’s not the right thing that I need. Where can I get just the main board to get my CM4 to work properly in my u console I don’t need everything else just the main board.
This is what you need.
Normal cm3 to cm4 adapters don’t work just the one made for the clockwork main board.
