As guu said, that really look like something is not correctly plugged. Try to reseat the cable to the screen, and the core module. Both carry critical signals that is they don’t transmit properly will led to (temporary) issues with the display.
yeah, tried that as well, and get same result. At least I can be assured the re-imaging went fine because it causes the same exact pattern of noise each time. So it definitely leads me to thinking it’s a hardware issue. I just wish it was as simple as the cabling being loose, but that doesn’t seem to be the case
Just to close this out… I contacted ClockworkPi Support and after sending some pictures of the screen, they determined the best course of action was to send a new screen. It arrived very quickly, and once installed, the DevTerm booted up fine. Based on this, I would deduce it was in fact a hardware issue.
So I received my original A04 with a screen that had a non-functioning backlight due to the flex cable being damaged, so I emailed Clockwork and they shipped out a replacement screen. In the meantime, I managed to fix the backlight on the original screen myself, and have been using that screen just fine. My replacement screen arrived, and it works just fine as well, until about 10 minutes or so of the DevTerm being on, and then it displays those same lines across the screen as shown in the OP. If I reboot, the screen works fine again for a little while and then does the same thing again. When I switch to my jerry-rigged screen, I have no issues.
