Show Us Your Customised uConsole
That looks cool… wow 4 Uconsoles in one place :D. Curious are those cases printed? or bought and if they are bought what case?
opps wrong post sorry
Looks great … did you post the stl files anywhere ?
If not would you consider sharing them ?
Thanks for your time
Ben
Where did you solder the battery leads?
Seems like the solder pads for the 18650 holder are clean :sweat_smile:
how do i get that screen protector
This looks amazing. I want to make the front plate on mine black and this is exactly the finish I am after.
I then want to laser engrave my own name and logo into it.
I thought about anodising but looks like a bit too much effort for me.
I’ve also looked at the black oxide method but have seen very different results achieved by others.
any update on this project. Would be a good one for the cm5 users.
Where can I get those red screws?
seems like it’s M4 screws, they are widely available
These are the ones I ordered. I cut 2ish mm from each one I used in the middle of the front plate.
https://www.aliexpress.us/item/3256802977082369.html
I love this black back
These are the ones I used because I wanted aome longer ones than the stock screw
https://www.amazon.com/gp/aw/d/B0CS944XYG?psc=1&ref=ppx_pop_mob_b_asin_title
Would that be the M4X6? Is it necessary to shorten them ordinarily, or did you need to for some other reason? I’m seeing conflicting information about the max length.
The bolts in the middle should be shortened, if you don’t it does stick into the case and almost touches the mainboard and expansion board.
Here are my 2 Uconsoles CM5 left Radxa Right. But not customised yet but soon with the Lora expansion kits.well i will have 3 uconsoles soon as a 3rd project.
My 2 cases came in today look amazing.
nice find. do you have a link to the case?
It looks to be OOS No2 I just found this on AliExpress:
£6.39 | Electronic Organizer DIY Sponge Protection Travel Cable Organizer Bag Electronic Accessories Carry Case Portable Portabl Storage
https://a.aliexpress.com/_EvO1Hhg
First test of this case. I make small changes then live with it for a bit. Next to add the hackergadgets antenna board.
Zak McKracken. Great game choice. :wink::ok_hand:t2:
