Slow blinking green LED on RPI board
Hello, I got PicoCalc and assembled it but it doesn’t seem to work. I have the SD card installed.
I inserted two charged 18650 compliant batteries but when I pushed the power button for 1 sec all that happens is the RPI board’s green LED slowly blinks with a blank display.
I’ve seen youtube videos where people assemble it and then push power button and it comes up in BASIC.
I can pull the batteries out and then hold the boot button and plugin a USB-B to the RPI board and it correctly shows up as “RPI-RP2” so I know the RPI board is working.
Did my RPI board ship with a blank without a UF2 image or something?
Thanks. ;-(
if so
try to drag a PicoCalc/Bin/PicoCalc SD/firmware/PicoCalc_PicoMite_v1.0.uf2 at master · clockworkpi/PicoCalc · GitHub
into the pico when RPI-RP2 showed up
To verify
Have you tried either 18650 alone and in either slot?
On a generic PicoMite device (I don’t have a PicoCalc) with the PicoMitte firmware loaded, the green LED flashes regularly as a heartbeat. So my assumption would be that you have a display hardware problem of some sort rather than a firmware or battery issue.
You could further confirm the PicoMite firmware is working by attaching a serial terminal to the USB-C port, you should find details of terminal configuration in the PicoMite manual: https://geoffg.net/Downloads/picomite/PicoMite_User_Manual.pdf
Best wishes,
Tom
Also double check that the display is correctly plugged.
Hello, has your issue been resolved? I am in the same situation as you
I copied the Picomite and then connected a USB-C and ran minicom as 115200 8N1 and I get:
PicoMite MMBasic Version 5.09.00RC5
Copyright 2011-2024 Geoff Graham
Copyright 2016-2024 Peter Mather
I2C Keyboard not found, OPTION KEYBOARD disabled
I then type in PRINT 1/7
> PRINT 1/7
 0.1428571429
> I2C Keyboard not responding
I’m not sure why I2C saying keyboard is not responding.
I have to pull the USB-C cable to stop it printing I2C… forever.
I guess the display is actually bad/defective! ARGH!
Thanks, but there is only one logical way to attach the display. The other would point the display at the PCB.
Nope. I was able to re-upload PicoMite and connect via USB-C and a terminal program and PicoMite responded. I guess my display is actually broken. Not sure what to do at the point. :frowning:
Thanks. I did that and did what @thwill said and was able to see PicoMite over serial via Minicom. But the display is still Blank. :frowning:
send email with your problem to help@clockworkpi.com
Thanks. I’m waiting for a response. :wink:
Hi, I emailed help@clockworkpi.com as suggested by @guu . They responded saying my display and PCB were broken and are shipping me replacements. :slight_smile:
Yeah, I got the replacement board and display and it works! :shortcake: :slight_smile:
So took roughly a week after reporting the issue ?
Running into the exact same issue with all the same symptoms. I tried everything that yall did and suggested. Thank you all for trouble shooting here, looks like I also have a bad display. Just emailed help and will see what they say, but encouraged that you all have had success after getting the new parts.
