I literally just assembled it. Have not updated the UF2 on it. The top “row” on my screen looks like this.
Anyone else get that?
I have already triple checked my screen connection. It’s straight, fully inserted.
Make sure your Pico is seated properly, I’d also try using flash_nuke.uf2 on it and then flash it with one of the other firmware on the SD card. If that shows up on a different firmware, you might have bad hardware.
Yep, I’ll try that.
I see a similar effect on the PicoCalc in this thread:
Strange, possibly the display itself as communication is serial. Fingers crossed for you..
send email to
I encounted the same problem. I hope they can find another model of the screen which is not that fragile.
