As the title says, I installed the hackergadgets.com NVME SSD upgrade and now, even after installing the adapter board, Pi OS doesn’t boot from the micro-sd card. Ive waited like 5 minutes, and recently the screen flashed white for a bit, and went back to black. This is usual, but it doesn’t take like 4-5mins to happen.
I need help with this. I found a little fpc-looking cable in the battery board’s bag, but didnt do anything with it, as I didnt know what. All I know is that my uconsole turns on, but doesn’t boot from the micro sd card I have.
looking at those images, did you make sure the compute module is fully seated? install the compute module into the adapter make sure both connectors are fully seated, and only then install both boards into the mainboard
Okay, uconsole still doesn’t boot into the micro SD card.
Is there anyway I could flash some OS onto the SSD, like can I boot into Pi OS, then connect the SSD, while its on? As I want to flash Arch linux onto the SSD, then copy most of my home directory from my micro sd onto it
I have no devices other than the uconsole (now) that has an SSD slot, what should I do?
So I know that there are specific packages added to the OS image to make it work with the uConsole. Did you get the image from the community or the official repository?
