Stuck power button
Hello.
Has anyone had issues with the power button getting stuck on the uConsole?
I’ve made the aperture slightly larger with small files - the button doesn’t get stuck now mostly - although it does as the unit keeps powering off during startup.
I’ve taken the back off. Press the button to start. Push the power button back up with a small screwdriver to get the unit to start. Ugh!
I’m guessing I need to ensmoothen (if that’s not a word I think it should be :slight_smile: the edges of the power button aperture a bit more…?
Greg
If you used the black button that was attached to the keyboard make sure you have trimmed the little silicone tit off it. I didn’t notice that they also come with a translucent one in the packaging. May try that one of the button keeps sticking.
Thanks Steve.
I’ve put the translucent button in - it’s nice to see the LEDs. :slightly_smiling_face:
Will try smoothing any rough edges in that aperture later - fingers crossed this works…
Greg
