uConsole AIO V2 (RTL-SDR/LoRa/GPS/RTC/USB Hub/USB 3.0/RJ45 Ethernet)
haver you tried checking the audio sink? I have that issue back then when I install DragonOS on my machine.
From Rex’s AIO board package: HackerGadgets AIO Board Package
If you’re using Trixie you’ll need to add an audio sink. On the left side scroll down to Module Manager . At the bottom of Module Manager type audio and select linux_pulseaudio_sink then click the + symbol. Then add the audio sink in the Sinks menu on the left side back up towards the top.
Hi
I did now, but i am on DragonOS even before the AIO2 updates and board , so expected that did nothing - check below my settings
Put the Linux sink to try and restart just in case
Same for CubicSDR
I am pretty sure if i could run Gqrx it would run- has happened in the past on Ubuntu
However if i use the Interceptor thing - it works and there is sound if something is up and static/noise if not
So i would probbaly do new fresh install later, was just curious why its happening :slight_smile:
Anyways decided to check just in case
I’ve been having issues getting the RTL to show up at all.
Looks like it should be on…
uname -a
Linux cheri.vpn.something 6.12.52-v8-16k+ #4 SMP PREEMPT Fri Oct 17 13:41:18 EDT 2025 aarch64 GNU/Linux
aiov2_ctl --status
AIO v2 Status
GPS   GPIO27: ON
LORA  GPIO16: ON
SDR   GPIO7: ON
USB   GPIO23: ON
Source    : AC
Status    : Charging
Capacity  : 100%
Direction : idle
Mode      : AC powering system
Voltage   : 4.23 V
Current   : 0.01 A
Power     : 0.04 W
lsusb
Bus 001 Device 004: ID 1a86:8091 QinHeng Electronics USB HUB
Bus 001 Device 003: ID 1eaf:0024 Leaflabs uConsole
Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
pinctrl | grep GPIO7
 7: op dh pu | hi // GPIO7 = output
sudo rtl_test
No supported devices found.
is the DVB blacklisted ?
Yup! That it is. Also had the previous AIO board with the SDR and it worked fine.
vvelox@cheri:~ $ cat /etc/modprobe.d/blacklist.conf
blacklist dvb_usb_rtl2832u
blacklist dvb_usb_rtl28xxu
blacklist dvb_usb_v2
blacklist rtl2830
blacklist rtl2832
blacklist rtl2832_sdr
blacklist rtl2838
vvelox@cheri:~ $ lsmod | grep dvb
vvelox@cheri:~ $ lsmod | grep rtl
Module                  Size  Used by
wireguard             114688  0
libchacha20poly1305    49152  1 wireguard
chacha_neon            65536  1 libchacha20poly1305
poly1305_neon          65536  1 libchacha20poly1305
ip6_udp_tunnel         49152  1 wireguard
libcurve25519_generic    65536  1 wireguard
libchacha              49152  1 chacha_neon
snd_seq_dummy          49152  0
snd_hrtimer            49152  1
snd_seq                98304  7 snd_seq_dummy
snd_seq_device         49152  1 snd_seq
squashfs               65536  0
rfcomm                 81920  18
algif_hash             49152  1
algif_skcipher         49152  1
af_alg                 49152  6 algif_hash,algif_skcipher
bnep                   49152  2
binfmt_misc            49152  1
axp20x_battery         49152  0
axp20x_ac_power        49152  0
axp20x_adc             49152  0
industrialio          114688  3 axp20x_battery,axp20x_ac_power,axp20x_adc
rtc_pcf85063           49152  0
spidev                 49152  2
brcmfmac_wcc           49152  0
panel_cwu50            49152  0
vc4                   425984  6
joydev                 49152  0
hci_uart               65536  0
snd_soc_hdmi_codec     49152  2
brcmfmac              376832  1 brcmfmac_wcc
btbcm                  49152  1 hci_uart
rpi_hevc_dec           65536  0
drm_display_helper     49152  1 vc4
snd_soc_simple_card    49152  1
bluetooth             638976  47 hci_uart,btbcm,bnep,rfcomm
snd_soc_spdif_tx       49152  1
cec                    65536  1 vc4
pisp_be                49152  0
snd_soc_simple_card_utils    49152  1 snd_soc_simple_card
cdc_acm                49152  0
rp1_aout               49152  2
brcmutil               49152  1 brcmfmac
aes_ce_blk             49152  4
v4l2_mem2mem           65536  1 rpi_hevc_dec
aes_ce_cipher          49152  1 aes_ce_blk
ghash_ce               49152  0
videobuf2_dma_contig    49152  2 pisp_be,rpi_hevc_dec
snd_soc_core          311296  6 rp1_aout,snd_soc_spdif_tx,vc4,snd_soc_hdmi_codec,snd_soc_simple_card_utils,snd_soc_simple_card
videobuf2_memops       49152  1 videobuf2_dma_contig
cfg80211             1032192  1 brcmfmac
videobuf2_v4l2         49152  3 pisp_be,rpi_hevc_dec,v4l2_mem2mem
snd_compress           49152  1 snd_soc_core
ecdh_generic           49152  2 bluetooth
gf128mul               49152  1 ghash_ce
ecc                    65536  1 ecdh_generic
sha2_ce                49152  0
sha256_arm64           49152  1 sha2_ce
snd_pcm_dmaengine      49152  1 snd_soc_core
snd_pcm               147456  5 snd_soc_hdmi_codec,snd_compress,snd_soc_simple_card_utils,snd_soc_core,snd_pcm_dmaengine
videodev              344064  4 pisp_be,rpi_hevc_dec,videobuf2_v4l2,v4l2_mem2mem
rfkill                 49152  7 bluetooth,cfg80211
sha1_ce                49152  0
libaes                 49152  4 aes_ce_cipher,bluetooth,ghash_ce,aes_ce_blk
snd_timer              65536  3 snd_seq,snd_hrtimer,snd_pcm
snd                   131072  11 snd_seq,snd_seq_device,snd_soc_hdmi_codec,snd_timer,snd_compress,snd_soc_core,snd_pcm
v3d                   212992  8
drm_rp1_dsi            49152  7
videobuf2_common       98304  6 pisp_be,rpi_hevc_dec,videobuf2_dma_contig,videobuf2_v4l2,v4l2_mem2mem,videobuf2_memops
sha1_generic           49152  1 sha1_ce
mc                     81920  6 videodev,pisp_be,rpi_hevc_dec,videobuf2_v4l2,videobuf2_common,v4l2_mem2mem
drm_ttm_helper         49152  2 drm_rp1_dsi
gpio_keys              49152  0
i2c_brcmstb            49152  0
raspberrypi_hwmon      49152  0
ttm                   131072  1 drm_ttm_helper
rp1_pio                65536  0
spi_bcm2835            49152  0
gpu_sched              98304  1 v3d
drm_shmem_helper       49152  1 v3d
drm_dma_helper         49152  2 drm_rp1_dsi,vc4
ocp8178_bl             49152  0
drm_kms_helper        245760  5 drm_dma_helper,drm_rp1_dsi,vc4,drm_shmem_helper,drm_ttm_helper
rp1_fw                 49152  1 rp1_pio
raspberrypi_gpiomem    49152  0
i2c_gpio               49152  0
i2c_designware_platform    49152  0
i2c_designware_core    49152  1 i2c_designware_platform
i2c_algo_bit           49152  1 i2c_gpio
spi_dw_mmio            49152  0
rp1_mailbox            49152  1
rp1_adc                49152  0
spi_dw                 49152  1 spi_dw_mmio
nvmem_rmem             49152  0
uio_pdrv_genirq        49152  0
uio                    49152  1 uio_pdrv_genirq
ledtrig_pattern        49152  0
drm                   688128  23 gpu_sched,drm_kms_helper,panel_cwu50,drm_dma_helper,v3d,drm_rp1_dsi,vc4,drm_shmem_helper,drm_display_helper,drm_ttm_helper,ttm
drm_panel_orientation_quirks    65536  1 drm
fuse                  196608  3
backlight              49152  4 drm_kms_helper,panel_cwu50,ocp8178_bl,drm
dm_mod                163840  0
ip_tables              65536  0
ipv6                  606208  65 wireguard
Would you know whether this script is compatible with the radxa board?
Update: I found at in a different thread that the scrip did not work.
Can anyone here point to the steps for the Radxa boards?
i am having trouble getting meshtastic to work. i checked the antenna connection and lora is enabled but meshtastic says it has no signal.
anyone run into this?
check your config, disable GPS and run meshtasticd in debug. see if there are any obvious issues.
solved in another thread. my channel was wrong, as compared o other nodes in the area
Do you all have working Ethernet on AIOv2?
solved
Ethernet Fix for uConsole CM5 with HackerGadgets AIO v2 Board
Environment
  • Device: ClockworkPi uConsole
  • Compute Module: Raspberry Pi CM5 Lite Rev 1.0
  • Extension Board: HackerGadgets AIO v2 (with RJ45 Ethernet port)
  • OS: Debian Trixie (Bookworm-based), kernel 6.12.67-v8-16k+
  • Device Tree Overlay: clockworkpi-uconsole-cm5.dtbo
Problem
After installing the AIO v2 board with its RJ45 Ethernet port, the eth0 network interface does not appear in the system. Running ip link show only shows lo and wlan0 — no Ethernet interface is present despite the hardware being physically connected.
Root Cause
The clockworkpi-uconsole-cm5.dtbo device tree overlay explicitly disables the Ethernet controller. Decompiling the overlay reveals:
fragment@5 {
    target-path = "ethernet0";
    __overlay__ {
        status = "disabled";
This makes sense for the standard uConsole which has no Ethernet PHY on its carrier board — the CM5 module includes the MAC (Cadence GEM via RP1 south bridge) and the MDIO bus, but without a physical PHY chip connected to the RGMII pins, enabling Ethernet would just produce errors.
However, the AIO v2 board routes the CM5’s RGMII signals to a Broadcom BCM54213PE PHY connected to the RJ45 jack. Since the overlay disables Ethernet before the PHY can be probed, the interface never appears.
Solution
Create a secondary device tree overlay that re-enables the Ethernet node. This overlay must be loaded after clockworkpi-uconsole-cm5 so that it overrides the disabled status.
Step 1: Compile the overlay
cat > /tmp/enable-ethernet.dts << 'EOF'
/dts-v1/;
/plugin/;
    compatible = "brcm,bcm2712";
    fragment@0 {
        __overlay__ {
            status = "okay";
EOF
sudo dtc -I dts -O dtb -o /boot/firmware/overlays/enable-ethernet.dtbo /tmp/enable-ethernet.dts
Step 2: Add to config.txt
Edit /boot/firmware/config.txt and add dtoverlay=enable-ethernet in the [pi5] section, after the uConsole overlay:
[pi5]
The ordering is critical — the enable overlay must come after the disable to override it.
Step 3: Reboot
sudo reboot
Step 4: Verify
After reboot, the Ethernet interface appears and the PHY is correctly detected:
$ ip link show eth0
2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN ...
    link/ether 88:a2:9e:38:b8:53 brd ff:ff:ff:ff:ff:ff
$ dmesg | grep eth
macb 1f00100000.ethernet eth0: Cadence GEM rev 0x00070109 at 0x1f00100000 irq 108
macb 1f00100000.ethernet eth0: PHY [1f00100000.ethernet-ffffffff:00] driver [Broadcom BCM54213PE] (irq=165)
macb 1f00100000.ethernet eth0: configuring for phy/rgmii-id link mode
After plugging in a cable, the link comes up at Gigabit speed:
$ sudo ethtool eth0 | grep -E "Speed|Link"
Speed: 1000Mb/s
Link detected: yes
NetworkManager automatically creates a “Wired connection 1” profile and will obtain an IP via DHCP when a cable is connected.
Suggestion for the uConsole CM5 Overlay
Ideally, the clockworkpi-uconsole-cm5.dtbo overlay should not unconditionally disable Ethernet. Users with AIO v2 (or any other extension board providing an Ethernet PHY) are forced to create a workaround overlay.
A cleaner approach would be to either:
  1. Remove fragment@5 from the overlay entirely — if no PHY is present, the macb driver will simply fail to find a link partner and the interface will remain in NO-CARRIER state, which is harmless.
  2. Provide a separate overlay (e.g., clockworkpi-uconsole-cm5-no-ethernet.dtbo) for users who explicitly want to disable it, rather than disabling by default.
  3. Document the fix in the AIO v2 setup guide so users with the extension board know to add dtoverlay=enable-ethernet after the uConsole overlay.
GPIO Notes
The CM5 exposes two Ethernet-related GPIOs:
  • GPIO32 (ETH_RST_N): PHY reset, active low. With the DT fix applied, the kernel manages this pin automatically via the macb driver.
  • GPIO37 (ETH_IRQ_N): PHY interrupt line.
These pins are not used by the AIO v2’s other peripherals (GPS=GPIO27, LoRa=GPIO16, SDR=GPIO7, USB=GPIO23), so there is no conflict.
@Rex
That was a mistake on an image that I put out and fixed it the next morning. You must have downloaded that image while I had it posted with the mistake in it. Newer images that’s fixed in.
Or can you try reinstalling the kernel to see if that fixes the overlay. sudo apt reinstall clockworkpi-kernel
I am having trouble getting uconsole yo boot with aio v2 installed. The hardware were Radxa CM5 32g, HG upgrade kit (Radxa adapter board+NVMe extention). System igame was the RadxaOS (debian12 based) that Rex modified and shared. The system booted normally without aio v2. With aio v2 installed, power was on as indicated by green light on clockwork mainboard. The blue led on Radxa CM5 was constantly on at lower brightness, similar to such state when aio v1 was installed.
btw this week will try to fix this with GPT - not wanting to reimage and and start again
even on the command line i get audio with the RTL and FM frequencies commands, but no sound if using SDR ++ bronw, SDR angel and others - so not working with the GUI , not the audio sink , still set as Linux whatever it was :slight_smile:
Will post a huge thread soon on what i have been using it though - its great even with the 4 GB model which limits me to only use tiny LLM’s for testing - like using tinny lama to explain captured RF signals in real time as educational test for kids/ people interested in radio - can be applied for the Wi-Fi and Lora stuff later down the line if using the command line . Simple bash script interracting with tiny lama or some other tiny LLM :slight_smile:
Too bad RAM and other stuff is way expensive due to AI shortage shit and all the wars/Covid/Scalpers in the last 5 years :slight_smile: Anyways ,sometimes the limitation get the best of your imagination :slight_smile:
How did you fix the chanel? I want to be on 0 also.
The V2 wouldn’t have the U-Boot issue like the V1. But the orientation of the early version ribbon cable matters. Can you post a photo of the setup?
Of course.
Looks good but dont leave that antenna connector floating around !!, risking a short.
I do notice differences of the ribbon cable I got compared to the photo on HG website indicating proper installation. The pin next to the 5v pin on the aio v2 side got a through holeconnected to the trace backside, instead of the third pin on the HG website. Also, is it recommended to attemp to power on with aio v2 installed but without ribbon cable connected?
I tried the old way when I was tinkering with aio v1 on Radxa CM5 described inTinckering with RTL-SDR AIO board V1 on uconsole with Radxa CM5, by taping the pin NO. 26&28, corresponding to UART2 TX/RX, the system booted normally. And according to my previous attempts with a version of u-boot that unabled u-boot console interruption in Tinckering with RTL-SDR AIO board V1 on uconsole with Radxa CM5, the problem may not just lie in the state of power of devices attached to UART2. I don’t know if there are testing contact points to see if there are unexpexted high levels on UART2 (espetially RX).
