Just got the uConsole/CM4 4GB to work with my Samsung Monitor (RGB to HDMI adapter) and logitec Keyboard/Mouse (shared) arleady had this working with DevTerm but you will need a linux program to link the two…
LOGITEC UTILITY - LINUX
sudo apt install solaar
solaar
From <Logitech Options on Linux - Ask Ubuntu
Just blew up my Spyder IDE then broke other things trying to repair - starting with a fresh image - thank goodness I have build notes!!!
Micro HDMI port has less plastic trim spacer in the connector than the DevTerm - less issue with external HDMI connectivity…
