UConsole bolt style
Hey folks
Does anyone know the name/style of the bolts used to keep the uConsole together? I know they are m4 in size but I’m not sure what I should be searching to find the same heads. I’m looking to get some longer versions so I can bolt extra stuff on the back of the unit. Thanks!
I believe this subject was covered under the heading uConsole screw size for alternate screws.
Found it. Thanks for the tip.
I needed some that were just slightly longer for a wifi antenna modification. These were a perfect match.
Amazon US: Amazon.com
Available from 6-20mm length.
Pictured here a 6mm compared to the included 4mm.
