Normally, when my uConsole is powered on, the screen may flicker momentarily when connecting an external Type-C power supply (Raspberry Pi 5 official adapter), but overall functionality remains normal.
Yesterday, I connected a MacBook Pro 2018 Type-C power supply to the uConsole and encountered a black screen and system crash. After restarting, I found that the Type-C charging function had failed, and there was noticeable electrical noise coming from the motherboard. I then conducted a series of tests and observed the following issues.
(The power adapter used is the official Raspberry Pi 5 adapter, and the recording device is a Sony PCM-M10.)
Without a battery, using Type-C for power supply:
When booting, the motherboard continuously emits a high-pitched “squealing” sound (confirmed not from the speaker).
After shutdown, the motherboard continuously emits a medium-pitched “beeping” sound, which stops immediately upon disconnecting the power.
With battery power:
The motherboard operates with relatively little noise during boot.
When an external Type-C power supply is connected, the charging indicator does not light up, and no charging occurs.
With an external Type-C power supply connected, removing the battery causes the system to shut down.
If booted with Type-C power first, then installing the battery:
The battery charging indicator lights up, and the system indicates that charging is in progress.
the uconsole type C does not use usb power delivery, it needs 5v, the macbook charger likely doesn’t provide that much current on 5v since that’s not it’s intended use case. Some part likely overloaded.
something on the uConsole board might have died. i have used normal USB-C with PD to charge my uconsole and everything is fine. PD is supposed to only send > 5V is it is negotiated for. by default, it would send 5V for a start. the MacBookPro power adapter would also do the same. i suggest you reaching out to Clockwork. but from the whining on the motherboard, it seems like something might have broken down.
The battery contacts are confirmed to be securely installed. I have disassembled all components and reinstalled them, but the issue persists. During this process, I found that without installing the CM5 core, there is no current noise when powering on, but in this case, battery charging cannot be enabled either.
I tried a fresh system installation, and the problem remains. (The device can boot using battery power alone or with Type-C power alone. However, it seems Type-C cannot charge the battery.)
The uConsole negotiates with USB-C PD to pull 5V using 5.1kOhm resistors on the USB-C CC pins as shown on the schematic (R510 and R511); using an Anker Nano II 65W USB-C PD supply capable of delivering 5V 3A (15W), my meter shows 5.3V 2.5A (~13W), so the maximum input wattage is probably nominally 12.5W. Meanwhile my Anker PowerPort III Nano 20W USB-C PD supply only delivers 5.1V 2.2A (~11W), despite also being rated for 5V 3A, so do with that what you will.
