I’ve found some M4 4mm black hexagon flat heads on AliExpress
These look like the ones I ended up ordering from aliexpress. They are pretty good quality. I’ll post pictures of how they look on black variant later today.
The internal screws are a bit shorter so there I used the original ones but the 4mm variant worked well for all outer side threads.
Note: Missing the stand retaining screws as I’m planning to add some D ring screws there for neck strap.
Those look awesome! Can’t wait for them to arrive for me
I found these on eBay. Looks like you can order different lengths.
Wow these kind of remind me of the devterm
https://www.accu.co.uk/plastic-knurled-thumb-screws/505643-SFTR-M4-6-BL
Amazon ones - the threads on these are two long - I got some in and will use a dremel to cut them back then clean up the threads by polishing. I put them in with washers and they where awkward in length
Would be nice to have thumb screws for the back panel, like the old desktop PC case thumb screws with knurled edges.
Do you know which size I should order some?
