I am probably shooting myself in the foot with this, as it is in my nature to install the OS, then immediately “sudo apt update $$ sudo apt upgrade”. The post install for the various “Upgrades” I have done, AIO V2 etc. bump into dependencies during the installation.
I have installed various OS’s on my SD Card, OVER AND OVER again for the last 2 weeks. I have been pulling what little hair I have left out because of this. It seems to be a “Damned if you do, Damned if you don’t” situation.
Should I just be happy with what is installed and wait for updates, or should be digging in and building an OS for my needs from the bottom up?
Ultimatly, I want to have one SD card setup and running intercept. So that I can plug it in, and leave it on my radio room desk, and access it from anywhere in the house.
I want an other SD card setup, so I can do SDR/WIFI monitoring around the homestead.
That should be && ! (two ampersands not dollars). This tells the system to run the second command IF the first one succeeds. The first one only updates the catalogue of software versions so it can check if any on your system have updates available…
I can do an apt upgrade no problem. I did get a lot of crashing with an SD card (im on nvme now), but I was assuming my SD card’s read/write speed is too low. I bought the cheapest one i could find
