More specifically, I’m interested in something like eagle files for the keypad.
I kinda want to see if i can modify it to add thumbsticks, it’ll be tight, but i think it might be doable
Am interested in this too.
Are these not sufficient?
@Cecilectomy Thanks for pointing out those resources which are useful as documentation for hardware hacking. But I don’t think these are enough to help design derivative works such as suggested by @KalTalen
Even the PDF files could (should?) have some sort of editable source file. Editing PDF is possible but it’s not its intended use. An inkscape file for example with the PDF would be editable.
For the schematic PDF what would be nice and hackable would be the source files that enabled to generate that PDF. For example KiCAD files or eagle files.
