3D printed cover for the uConsole
I just finished the design of a cover for the uConsole. The STL file is posted on the Discord 3d-printing channel. Seems to work well. I did the design in OpenScad, will share that file if anyone wants to make adjustments to it.
It is just under 8 hour print with my settings and doesn’t need supports.
Nice! This is the exact kind of thing i was hoping someone would make. I have always been a fan of the clip-on style hard covers like the TI calculators use and this would be perfect for protecting the uConsole while in my backpack.
Someone else made a cover for the DevTerm, that works well. I wanted one for the uConsole and finally managed to get it together.
It would be awesome if you could post the OpenSCAD source files! Since someone brought up TI calculators: does it have a mechanism to clip to the back when device is in use?
I have the Ops Shield for the DevTerm - love it - it fits more like an early cell phone case - protects the fragile edges from getting broke should you drop it - it has lanyard tie points as well - 3d printing is a hobbyist dream! I used to make things out of cardboard and fiberglass resin … I still do!
Here is the OpenScad file to generate the cover. It really isn’t that big of a file.
https://zjunk.net/uConsoleCoverV2.scad
For those that haven’t used OpenScad, it is free and works on many different machines.
Here is the STL file
https://zjunk.net/uConsoleCoverV2.stl
Cool, thanks a lot! Nice and compact code actually.
I will just quickly copy-paste it down here so it may be more convenient to grab for other users:
// uConsole cover version 1.0
// Created by Mark Bauer
// Use this file how ever you wish.
// If you decide to sell the product and feel guilty about it, don't feel guilty.
// you might give me credit for it though.
// If you make a gazillion dollars from it, you can give me a cut.
//  BTC address  16WFNyEKCfNnZvQWu2NTqdcMGwUQV6tvSn
// changes 7/20/23  changed the radius of the corners a bit.
module roundedBoxBev(x,y,hz,r,bv){
  // this is a generic brick with rounded corners.
  // bv is a bevel on the bottom side only.
  // you use the difference() function with another box to hollow it out.
  up = bv;
  difference(){
    union(){
      translate([r,0,0])cube([x-(2*r),y,hz]);
      translate([0,r,0])cube([x,y-(2*r),hz]);
      translate([r,r,up])cylinder(r=r,h=hz-up,$fn=64);
      translate([x-r,r,up])cylinder(r=r,h=hz-up,$fn=64);
      translate([r,y-r,up])cylinder(r=r,h=hz-up,$fn=64);
      translate([x-r,y-r,up])cylinder(r=r,h=hz-up,$fn=64);
      translate([r,r,0])cylinder(r1=r-up,r2=r,h=up,$fn=64);
      translate([x-r,r,0])cylinder(r1=r-up,r2=r,h=up,$fn=64);
      translate([r,y-r,0])cylinder(r1=r-up,r2=r,h=up,$fn=64);
      translate([x-r,y-r,0])cylinder(r1=r-up,r2=r,h=up,$fn=64);
    translate([x/2,0,bv-1.4142*2])rotate([45,0,0])cube([x,4,4],center=true);
    translate([x/2,y,bv-1.4142*2])rotate([45,0,0])cube([x,4,4],center=true);
    translate([0,y/2,bv-1.4142*2])rotate([0,45,0])cube([4,y,4],center=true);
    translate([x,y/2,bv-1.4142*2])rotate([0,45,0])cube([4,y,4],center=true);
module cover(){
  difference(){
    union(){
      roundedBoxBev(136,179,3.0,8,1.0);
      translate([0,179,3+6])rotate([180,0,0])roundedBoxBev(136,179,6.0,8,3.0);
    translate([2,2,-0.001])rotate([0,0,0])roundedBoxBev(132,175,3.0,6,0.0);
    translate([4,4,-0.001])rotate([0,0,0])roundedBoxBev(128,171,7.0,1,0.0);
  // part at the top
  translate([(136/2)-50,179-2,-3])union(){
    cube([100,2,5]);
    translate([0,0,0.0])rotate([0,90,0])cylinder(h=100,r=2,$fn=32);
    translate([0,0,-0.9])rotate([45,0,0])cube([100,2.5,2.5]);
    translate([0,0,0])sphere(r=2,$fn=32);
    translate([100,0,0])sphere(r=2,$fn=32);
  // foot
  translate([(136/2)-50,0,-17.7]){
    cube([100,2,20.5]);
    translate([0,2,0.2])rotate([0,90,0])cylinder(h=100,r=2,$fn=32);
    translate([0,2,-0.6])rotate([45,0,0])cube([100,2.5,2.5]);
    translate([0,2,0.2])sphere(r=2,$fn=32);
    translate([100,2,0.2])sphere(r=2,$fn=32);
// intersection(){
   cover();
//   translate([60,-7,-25])cube([5,20,50]);
// test1();     // just used to test how things fit before I print the whole thing.
Someone sell me a black one please i will review it and give full credits :slight_smile:
Are you in the us?
Extra characters…
Hi i am from the UK jutleys you can search us RGHANDHELDS
ahhh, that’s too far to ship. :rofl:
Hopefully someone in uk with a 3d printer can do it soon.
If you do print the cover I designed, let me know how it worked. If you made changes to the OpenScad file, I would like to see images of that also. Fun to see what people do with this stuff.
Printing now. Mine have holes :slight_smile:
Added this to the Code:
module pattern() {
    translate([10,10,0]){
        for(y=[0:10:179-20]){
            for(x=[0:10:136-20]){
                translate([x,y,0]){
              cube([5,5,10]);
// intersection(){
   difference(){
   cover();
    pattern();
At first I was like how did that happen. That is neat, send a photo of it when done. Thought about adding optional pieces on the side to cover the ports.
Just printed mine. Fits perfectly, and done slightly over 7 hours.
Nice work @markatlnk!
Done. Maybe some organic support for the bevel and a brim against warping :thinking:
I kept the overhang angles at about 45, mine came out nice. Just used PLA. It gives me ideas for other hole patterns. Maybe a hex grid.
Sure, you can make anything here. not only cubes. Go wild! :-))
