4G Module Antenna
Hello, recently I got the uConsole Antenna Board accessory meant for the LoRA module, but I am just using it as an antenna board right now for wifi and 4g. So far I haven’t been able to get the 4g module to actually pick up a signal. I’ve tried all three of the antenna connections of the 4g module itself, but all of them result in poor, or usually 0% signal. I assume the connection labeled “main” is the one I want.
My 4g module is also still on the 9001 firmware. I’m a bit nervous about upgrading it because I’ve read that you can’t downgrade it later, but I’ve also read that the 9011 firmware is more consistent.
Any advice would be super appreciated :slight_smile:
Make sure the antenna you are using is tuned for 4g LTE, i think each different network uses a different type of antenna.
Small update on this, I brought the uConsole with me on an errand and during its time in the car, it actually picked up a signal. Now it works inside the house and I’m having registration issues, which I have some ideas to solve. I know that my house is not great for wireless signals, but it seems strange to me that it’s fine inside after having been outside, but can’t seem to get a signal inside from a fresh boot.
Your house must be built like a bunker. 'Nuff said.
Kidding. I have the same issue in a different location. Cellular coverage is garbage (I use the default antennas), and so said my phone too.
Yeah it’s not nearly as much of an issue with my phone anymore, but I’ve lived here at different times across about 23 years… it’s always been a little bit of a nightmare for cellular. I guess it just needs to get an initial strong connection and then it has an easier time maintaining that afterward.
Hi,
I’m in France, out in the countryside. With a smartphone, I get around 2 to 3 Mb/s on 4G.
But with the uConsole and its stock antenna, I get no signal at all, and zero bandwidth.
I tried using an antenna from an old laptop (the internal screen antenna), and was able to recover the same signal and speed as the smartphone.
Then I took the time to buy the small antenna mounting kit from Hacker’s Gadget, and installed two 4G antennas I had salvaged from an unused 4G modem. And now? I’m getting around 15 Mb/s, 67% signal strength, and I can even make perfectly clear calls.
Sure, the antennas are a bit large, but the improvement is huge.
Bonus:
While I was setting everything up, I had a fiber outage. I managed to share the 4G connection and set up the CM4 as a hotspot, which allowed me to work for two full days until the fiber was restored.
In short: awesome!
did you tape the stock antenna to the case like instructed? because for the wifi antenna it’s well known that that kills the reception
At first, yes, I did tape the stock antenna as instructed. But due to poor speeds, I ended up adding a Wi-Fi antenna to the kit as well. I now get a reception rate of 480 Mbps, and in practice with iperf3 I reach around 115 Mbps — roughly 10 MB/s, which matches the CM4’s actual throughput.
Just a quick update from my end. With a bigger external antenna, and sometimes also an auxillary antenna plugged in (not sure if that’s actually working), I’m able to get consistent connections in my house. I think part of the issue before is that the modem did not have a chance to register with a valid service, which was causing inaccurate reporting of the signal value, which was causing me some confusion.
