I wrote it as a blog
https://blog.estela.moe/2024/10/27/build-your-own-linux-for-uconsole-a06/
Repaired, thanks. hard reload if colour not taking effect. It seems something was broken in last update
hello Is there any way to do the same with kali linux on A06 or dragon OS for raspi ?
hey, all the same except the packaging part, you will have to make the deb kernel package with patches.
this page may help:
https://kernel-team.pages.debian.net/kernel-handbook/ch-common-tasks.html#s-common-official
So I can I manage this ?
I retreive a raspi kali image or a dragon OS raspi image . I put it on a SD card and then ?
I have to patch using a raspi board ?
Native kali or dragon won’t start on the A06 clockpi board
Flashing the raspi image is not expected to work.
You will have to follow “Preparing the SD card”, “Build U-Boot” chapters in the blog (so at least it will boot), then follow Chapter 4. Common kernel-related tasks to make a kernel package with patches given at GitHub - saeziae/linux-clockworkpi-a06u . Then continue with mounting the sdcard and extracting rootfs and so on like “INSTALL THE SYSTEM” chapter.
I am not familiar with Deb packaging so i can’t give detailed help about that part.
Following your instructions but i am a little confused on this part:
At the fdisk prompt, create the new partition, we are separating boot and root in order to use f2fs for rootfs:
UPDATE:
The required packages needed for compiling are not listed in the tutorial. I have received and error and cannot figure out what package is needed for a successful compilation:
In file included from tools/lib/rsa/rsa-sign.c:1:
./tools/…/lib/rsa/rsa-sign.c:22:10: fatal error: openssl/engine.h: No such file or directory
22 | #include <openssl/engine.h>
UPDATE2:
Got rid of the error by compiling openssl locally
Now i get signature errors on:
sudo pacman -S aarch64-linux-gnu-gcc aarch64-linux-gnu-binutils aarch64-linux-gnu-glibc aarch64-linux-gnu-linux-api-headers:
66/66) checking keys in keyring [#####################################] 100%
(66/66) checking package integrity [#####################################] 100%
error: linux-api-headers: signature from “Frederik Schwan freswa@archlinux.org” is unknown trust
:: File /var/cache/pacman/pkg/linux-api-headers-6.10-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n]
Hello i reply from email bc github login of clockworkpi forum is not
working, i hope it appears.
for partation magic, it comes from archlinux arm’s rockchip instruction,
it’s an offset between partitions.
about compiling:
install openssl
about sig error:
system too old, install keyrings first then full update the system:
pacman -Sy archlinux-keyring
pacman -Syu
pacman -Sy archlinux-keyring gives me the same error:
Total (60/60) 76.5 MiB 8.50 MiB/s 00:09 [#####################################] 100%
(102/102) checking keys in keyring [#####################################] 100%
(102/102) checking package integrity [#####################################] 100%
