Beer fund for someone who can create a current os?
Hello all, i would be glad to contribute to a beer fund (usd 5 - usd 10) to say thank you to someone who would port the kernel changes to the current version of raspberry os. I would think others may join
Any takers please?
there is already one, it is in the postmarket-os repo, but its a new kernel. worst case it requires a reconfigure and a rebuild, but it should work on bookworm.
I do not know how to do this. I gladly pay you a beer if you are willing to try?
sadly i only have a CM4 with eMMC, so i cant swap SD cards for such tests and i dont want to ruin my current setup :slight_smile:
I mean couldnt you just copy your emmc to an sd/hard drive as an .img using dd, i mean it would be a good way of backing it up not just to share the image
sure, but i would have to disassemble and reassemble everytime i need to change something on the kernel, which would be required a lot when working with kernels and the cm4 connector doesnt seem like it could withstand a lot of re-plugging.
I’ll pitch in 10 USD. I’m really surprised that there isn’t anyone in this community of enthusiasts whos already pumping out the builds. Somebody get Jeff Geerling on this stat!
Snoozer did you give up on your attempts? I see your GitHub hasn’t been updated in a while.
No just been working on other stuff i had in mind, pwnagotchi, steam, esp32s… but i have a spare 32gb sd card to work on the os side of things again. I did have a little look see on the guide the guy who did the kali image did. Its a lot smoother as a config so ill be updating my guide soon.
Will probably have a crack at it tomorrow, today was all kinds of busy with both my own projects and tortoise sitting.
i uploaded my compiled kernel (tbh the complete /boot) from postmarketos to my github repo:
https://github.com/krim404/uconsole_sway/raw/main/boot.zip
this should be the official raspi kernel 6.1.74-v8 with all requirements for the uconsole patched in.
maybe someone wants to try if this kernel is bootable with raspberry os bookworm without any modifications.
If yes i would volunteer to create a bookworm based image ready to flash using raspi imager.
I have in mind of making an arch/manjaro img with latest rpi kernel (6.6?). Anyone interested?
Snoozer-94 I guess is your github, right Snoozer?
I do have plans on doing manjaro but if you make it and upload it ill link your github to it, i kinda need to do some maintenance on my github anyway
Good by me, I still don’t have it yet so, another pinned thing xD
Sadly, it’s not going to work, because you are not providing your kernel modules, which are out of /boot in /lib/modules/
duh sorry seems like my brain was already in weekend mode. Will upload them shortly.
→ https://github.com/krim404/uconsole_sway/raw/main/modules.zip
I would support that and chip in as well for a full flashable image
Unfortunately, did not work for me. How was I testing:
  • got official 2024-03-15-raspios-bookworm-arm64-lite.img
  • dd’ed it to sd card, put it into hdmi-connected uconsole, to make sure ir boots
  • it booted with external monitor, and went initial setup
  • powered off uconsole, removed sd card, mounted its root and boot on another linux machine, removed contents of the boot altogether, extracted boot/* from boot.zip there, and modules/* modules.zip to lib/modules/, doublechecked paths and file permissions, umounted partitions from linux and put it back to hdmi connected uconsole
  • power button reacts, screen backlit goes on, but no any output on both internal screen and HDMI
thank you for testing. just to make sure: did you extract the whole boot config or did you only overwrite the vmlinuz and initramfs?
The whole boot/ , like:
sudo mount /dev/sdb2 /mnt/
sudo mount /dev/sdb1 /mnt/boot/
sudo rm -rf /mnt/boot/*
sudo unzip boot.zip -d /mnt/
sudo unzip modules.zip -d /mnt/lib/
afaik bookworm has a different boot layout (using boo/firmware etc). can you try again only changing the kernel?
