Ok, downloaded your image from before. Used the Pi imager to write it to the system. Told it not to customize things. 32G SD card. Renamed the config.txt as configOld.txt and installed the new text as you provided.
It is really close, I did see the display come to life several times with the pi boot stuff and even the image. I expected slower boot as it resized things. I must have flashed something on the display 4 or 5 times at various points. After about 5 or 6 minutes, there is a blinking cursor in the upper left corner of the display but it looks like it is in text mode. The blink is a rather odd pattern that repeats.
After about 10 minutes, I decided that it wasn’t getting any further. A short press on the power button doesn’t do anything, so the system isn’t up. I can tell the 5V sub system is powered as the USB ports have their 5V.
Holding the power button for 30 seconds or so, the power light does go out. The charge LED was still lit as I was plugged in. Unplugging that, the 5V system is still powered up with all other indications that it is off. We had this problem long ago.
Power up again… About 45 seconds into the boot, I get the “Welcome to Raspberry Pi” display again looking good as it lists modules being loaded, but it blanks after just a couple seconds and the cursor just blinking oddly in the upper left is like it was before.
Connecting an external monitor to it and rebooting a few more times. I did get a message on both displays about not being able to enumerate a USB device, but that only happened once.
So far all attempts end with the blinking cursor in the upper left.
I yanked the sd card out while it was with the blinking cursor. Interesting that I am getting the continuous error messages from not being able to read the SD card. So the display is up and running, but in text mode.
I can do the Alt F1 → Alt F9 to see different screens, but none of them are the graphics. Error messages eventually show up in all of them (SD card still out).
What else would you like me to try?
