My wife was wondering as well if I am making something I shouldn’t ![]()
I couldn’t get it running on KDE, runs on Labwc though so it’s not a kernel issue. Also V3D works in KDE but not Labwc, so still not kernel related. ![]()
Mine is running in KDE. ![]()
I followed this to the letter:
CM4 8GB. Running the lite version of your image Rex with KDE installed.
Also have 256gb SD and made sure all partitions have plenty of breathing space.
Might be something with the CM5 and KDE then that’s what @Kirou has has also.
Hi Rex, thank you so much! I have updated the kernel to 6.12.18, but still has a problem with the hard reboot. I can not turn it off when it gets frozen by holding the power button, still has the dim green light. I am using CM5 Lite 8GB. Thanks Rex!
If it’s frozen the power button won’t do anything as of this time.
charging lamp back now after updating kernel 6.12.18… thanks @Rex
Rex, thanks so much for all your work here. With your help, I now have my uConsole fully working with the CM5 and working well. I added the Sleep 1.2 functionality and did pretty much all of the tweaks you and others suggested. Keep up the great work. It is appreciated.
What is this “Sleep 1.2 functionality”?
We need a wiki where all the suggested tweaks can be posted.
My guess: uConsole-Sleep v1.3
After hours of relentlessness, and litres of sweat later, that’s it! Waydroid works! I passed the kernel in 4k pages… thank you @Rex for the additional information, which helped me a lot for the rest of the configuration.
And wine works too.
I just want to confirm that manually upgrading from older (Kernel 6.6.x) images works on a CM4 uConsole. Running a quite tailored to my needs Bookworm lite image that I installed last summer, I did not want to loose the install and tried upgrading instead.
apt install clockworkpi-kernel clockworkpi-cm-firmware
did the trick while removing clockworkpi-CM4-kernel. It is now proven that this can work but it will of course always depend on your personal installation and configuration.
I have a program that i used to use the mouse wheel to zoom in and out with. Is this functionality already built in or do i need to customize my keyboard file?
That’s part of the keyboard firmware. Check out the updated ClockworkPi uConsole firmware in their GitHub or the community made QMK firmware.
So I figured out whats wrong, it was a mesa update. I made the current image the day after that update came out so a reflash won’t fix it but I used the script here someone made to fix the problem. I used it but did have some extra stuff on my system and borked it good. ![]()
On a fresh flash I used that script and downgraded mesa and now glmark2-es2-wayland works as intended.
I’m sure there will be a update to fix it in a day or so from Raspberry Pi. So no need to run out and start putting stuff on hold.
Did some testing of my battery mod and CM5:
On average - 3h of runtime on very high load (medium brightness, 85% CPU, and SDR++ listening to FM radio).
Max load with full brightness - 2:20h.
Everything is stable.
Charge time with the new charge board is around 3 hours. It pulls 12-15W at 5v from the charger.
The battery indicator is useless as expected. It will decrease and show 5% for a long time. It will reset only if the battery pack low voltage protection kicks in (basically disconnecting power to the main board entirely).
As soon as there is a fix to GPU usage - will retest Youtube playback and general usage time on battery.
Hi @Rex,
I’d like to thank you for your continued contributions to this community.
I flashed your latest image using RPi imager on my uConsole with CM5, and it works flawlessly. Appreciate all your efforts to make this possible.
Hi @Kirou , I face the same problem of waydroid on CM5 Lite. Could you please share how did you make it work? Thanks.
By default with the CM5 you’re using a 16k page size. You need to change to the 4k page size kernel. I guess they just haven’t added support yet. To change all you have to do is add kernel=kernel8.img too the [all] section in /boot/firmware/config.txt
@Rex said it all! I used the barbarian method, I installed Wine with PiApp, which automatically switches the kernel to 4k. I’m still a noob who learns ![]()
Thank you for giving the right method, Rex. She is much better!
EDIT : I have no problem with 4k pages kernel. No issues to boot, reboot or other bugs.
