Hi just to say the DevTerm arrived for me and it is great!
I just wondered if anyone can help with a few issues I’m having?
By default the username and password is cpi
So I changed my username and password using usermod.
I don’t know if it is related but when I now download files to my home folder they seem to be corrupt (not sure if permissions or groups are messed up etc).
The same files downloaded on my other Linux box are fine, but on the DevTerm they won’t open…
My other issue seems to be with the printer. It does print, but the printout has a lot of lines running through it and seems to also get a bit scratched by the rip teeth too. It also sounds like the cog is struggling a bit. Is this a common problem? The print lines seem odd, I can take it all apart to try re-fit things if you think it might be how I’ve put it together that
is the cause… but everything seems to be located OK.
Lastly, again with the printer: How do you add it fresh in printer settings? What is the URI etc?
Other than these teething problems the DevTerm is ace!! Thanks
