Howdy folks!
I was curious if the DevTerm has some kind of charging indication when the unit is powered down and connected to the USB-C-cable.
There are two LEDs mounted on the DevTerm‘s mainboard located near the power switch. One is obviously the power-LED. When referencing the mainboards layout in GitHub I can clearly identify the second LED connected to the „charging LED“-Pin 52 of the powersuply/BMS.
Can anyone confirm that the LED should light up whilst charging? Or is this feature not implemented yet?
Greetings Nico
