Perfect!!! Thank you so much. This was the kind of feedback I was looking for re how to improve the image.
I know exactly what to do to fix the rom directory problems; and what I did to break it! Can you confirm which emulators didn’t work re SFC and MD? I mainly was testing the standalones, so I am guessing it was the Retroarch cores. I will post up updated action.config files, and upload an updated image.
Strange that changing themes does that! I admittedly only changed and toggled the DEOT and Default themes, since I don’t use OP-1.
Was it OP-1 you had problems with?
This is possibly related to the custom fonts required of the DEOT theme and the modified skin_chooser.py. I’ll simply restore it to the stock one, and forego the fonts. (And find a better way to use custom fonts!!! Grrrr!!)
I’ll provide instructions for those who want them, but also update this in the next release.
In a nutshell, just change your skin to the default, then go into ~/launcher/sys.py/UI, then find the file called skin_chooser.py, rename it to skin_chooser.py.bk or something, then rename the file called skin_chooser.py.bak to skin_chooser.py. (Or was if skin config? I’m just writing this from memory in bed haha)
Afterwards, reboot the system.
- A lot of the Chinese would have to be hard coded into the emulators, which unfortunately I didn’t write. Also my Chinese is SHOCKING, despite being Chinese myself. If they ever release translates versions of the standalone emulators, I will be happy to include them!
Again, thank you so much for your HELPFUL feedback!
In other news, @wizz has provided a helpful mirror for the download: https://pcroz.stackstorage.com/s/a26iBYxvkQ5VSgS
@guu - hopefully this mega link will work. MEGA
The previous one was one I provided while it was still uploading. I couldn’t get the permissions properly sorted, and was way too tired haha!!
For those curious of @wayfarer’s problems, the solution was cross posted across a few threads, including this one. Summary: user downloading problems.
Their mupen64 problems were resolved as well.
