I’m using ‘master’ branch of ‘RetroPie-Setup’ and its hash is 6e80c1bdc33284386a8a33ca7d7485070b446da4
I saw that someone on the forum had already successfully gotten RetroPie to work, so I figured it would be no big deal, but crucially, the D-Pad is not recognized and the screen is displayed directly in the X-window running, but rotated 90 degrees in the Console state. I can’t proceed with the Emulationstation initial setup because my D-Pad buttons are not recognized.
I’d love some advice from those who have already successfully set up RetroPie.
I also applied the SDL_GAMECONTROLLERCONFIG setting, but the VVVVVV game doesn’t detect anything but the ‘A’ button.
I figured out why buttons were not working in VVVVVV game and others.
It was simply because of wrong value of SDL_GAMECONTROLLERCONFIG. (I copied and pasted its value from somewhere in this forum before)
Anyway, the correct value are x:b0,a:b1,b:b2,y:b3,back:b8,start:b9
And also you may need to add the following line into ~/.zshrc or ~/.bashrc, depending on your shell. I personally prefer to add in /etc/environment. (In that case, you don’t need to ‘export’)
It s strange because gamepad works very well with ppsspp emulator. When I use retropie, gamepad seems not detected, or as another gamepad. I tried all above on this page…still message in retropie “Uconsole gamepad not configured” when I launch a game.
