Hi there! Ever since I received my Devterm, I have been unable to get the speakers to work. I disassembled and reassembled the device two times hoping that would resolve it magically but alas! No luck. When I try to check the sound settings, it appears the OS doesn’t even recognize that there are speakers present.
I did the mistake of assembling two speakers in the same orientation, when the instructions called out for one speaker to face opposite to each other (if I remember correctly). This resulted only one of them worked. I changed it accordingly so now it works fine for both!
But your case sounds new to me, so check to contacts. If it’s dirty, a small dab of alcohol will fix it.
