Display broken or firmware issue?
Hi,
After replacing it with pico2w and installing micropyhton, nothing is displayed on the display. Even if I switch back to the original pico, nothing is displayed.
Therefore, I want to distinguish whether the monitor cable is broken or the firmware is a problem.
Will it return to the factory firmware if I just write PicoCalc_PicoMate_v1.1_pico2.uf2 found here?
thanks,
I often forget to replug the display cable. I guess you double checked.
Also, you can use minicom or similar to see if you get output on the serial line (usb C connector).
Also, if I remember correctly, first time I uploaded micropython, I had forgotten to copy the .py files to the internal flash, and the screen was showing nothing.
probably you broke the display
write email to help@clockworkpi.com and they will send you replacement
TO check if is device broken
I recommend to use pico1 ,with this firmware
For pico2w and micropython
here is a quick try pre-compiled verison, all you have to do is just flash the uf2 into pico2w and that’s all, these quick try pre-compiled uf2 already contained main.py
here is the pico2w micropython uf2 file:
If all above uf2 failed to work,then there must be something wrong with device
Hello,
Thank you for your reply. I will follow your advice. Once I have come to a decision, I will reply here.
Thank you in advance.
best,
